Questions on storage: Fusion to SSD or two drives?
Hi @danj , not sure u will see this comment but after reading this i think you can really help me.
Few years later after 2019 we have here 2024, and there is an 2017 5K iMac in front of me, inside is still original 1TB HDD with Fusion drive but its slowly but for real dying.
I have experience from Windows that changing 2,5” SATA SSD for HDD helps, but if you compare to NVMe speeds its still slow as hell.
I was about to buy Sintech adapter and buy an Samsung 990 PRO 2TB blade and change it for fusion drive and the SATA connector not conected. It is very important to me that the disc will last working without problem as long as possible without any errors and ofc with the best speed...
so, what do you recommend?
1. Leave fusion drive in slot just change the HDD for 2,5 SSD (i think there is also some adapter needed)
2. Buying OWC 1 or 2TB blade SSD that will fit the motherboard without any adapter
3. Sintech adapter and Samsung 990 pro 2TB (2 just bcs there should be better tbw than on 1tb and less)
The iMac is being used for work on graphic projects (mostly just reviewing) lot of open apps, Windows and tabs and we need that the drive will last longest as possible at the best speed possible...
Thank you very much for your answer I’m already reading everything for 2-3 days and just today i changed my opinion from Samsung to OWC..
but I believe you got much more experience...
Ist dies eine gute Frage?
