no boot no display no beeps but loud fan gpu and cpu - RESOLVED
Hello guys, I hope you are doing great, well yesterday I used my pc normally ( new build - 1 day ) then I turned it off so I could sleep, and then today I tried to turn it on, but there is no display no beeps and no post, sometimes the gpu fans its RPM goes so high and loud, and the RGB on GPU or Fans is ON, any tips what it could be ?
I tried removing CMOS, Cables, RAMs, shorted the two pins to default the BIOS ( JBAT1 ) nothing could fix it I also remember Overclocking my RAM and CPU but they were stable, their temperature were below 60 and everything is good, I dont know what happened
Config :
RYZEN 5 4500
B450M A PRO MAX
VENGEANCE 16 GB RAM
AIGO 500W
RX 580 4GB
Please any ideas ?
Ist dies eine gute Frage?
Did you happen to update your BIOS while the machine was running?
Your motherboard also looks like there are some debug LEDs above the 24 pin motherboard connector. Are any of those LEDs lit?
von Alisha C
@flannelist Hello, thanks for the reply, no I didnt update any BIOS, it is my first build, it ran for a day then this happened, there are no debug leds on this specific motherboard.
von KJ aetos
@kjaetos I just pulled up the manual for the B450 A Pro Max (it's an MSI board, right?) and it shows them right above the 24 pin ATX connector. They might be hiding if you have cables running through that area.
von Alisha C
@flannelist Oww my bad it is a B450M A PRO MAX
von KJ aetos
@kjaetos
What are the debug lights showing if anything?
von jayeff
6 weitere Kommentare anzeigen
