Zum Hauptinhalt wechseln
Repair and disassembly information for HP 15s Laptop PCs, specifically 15-dw models. The HP 15-dw is a lightweight and portable, mid-range laptop series designed for everyday use, featuring 15.6-inch displays, 11th generation Intel processors, DDR4 memory, and SSD storage. Identified by model numbers starting with 15-dw or 15s-dy.
4 Fragen Alle anzeigen
Battery replacement 15-dw3021nia S/N CND04651YZ
I found 2 models HT03XL which is the original replacement of my battery, and also an exact similar model TF03XL. the later seemed to be with higher voltage 11.55v, higher capacity, and 33% cheaper above that... looks like a battery with more advanced cells, and I want it instead of my same old battery, but I am not sure if it is compatible. on HP site there was a couple BIOS updates to support new battery models, but they didn't list what are these new models. is this battery TF03XL compatible with my laptop?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
From what I can tell it is not compatible, unfortunately.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Packet Loss Gamer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 128
