Zum Hauptinhalt wechseln
Das Smartphone Motorola Edge + 2022, hergestellt von Motorola, gilt als das höherwertige „Plus“-Modell der Edge-Serie.
I need to replace charger port and daughter board. Are these parts ava
I'm having intermittent charge port connection failure. Is the charger port alone and the charger port/daughter board available as replacement parts anywhere?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
I actually did this repair and detailed it here. I'm not sure why the post wasn't on the ifixit site???
I'm in the USA. This was not a popular phone here and Motorola offered no support. I was able to purchase a refurbished part from eBay that had a new USB port reflow soldered in. The phone and charger port worked quite well, however when I readhered the back cover on it affected the speaker somehow and left my phone so quiet I simply gave up on it and went back to my old Samsung S-22. Which I dislike. A lot.
War diese Antwort hilfreich?
Bewertung 1
@rey63866 typical Motorola numbering system messes everybody up. Check if your phone is a XT2061. Yes, the charging board is available but we need to verify your proper number. IF you already have it apart, post some good pictures of the board with your Question. That way we can see what you see.
If your phone is sitll togethre. go to Settings > About phone > Model > Model Number (SKU)
Bilder zu einer vorhandenen Frage hinzufügen
Bewertung 0
3 Kommentare:
It is indeed XT2201-3. It was purchased directly from Motorola. It's called Motorola Edge+ (2022).
It has exhibited the usual " only charges when cable is plugged in with certain orientation, turn over plug, doesn't charge or slow charges.
I don't have hot air reflow to mount a new smt usb-c port, which is why I'm willing to purchase the daughter board assembly as long as it's less than ⅔ of the cost of a hot air rework machine. (+-$35) This has been a great phone and I've stuck with Motorola since the first Gen Moto E and G. I'd like to stick with this one for a bit more...
von
@rey63866 absolutely. I myself prefer to replace the charging board instead of soldering USB-C connectors. It's a lot easier. Looks like the part number for your charging board is SR28C51352 Do an online search and see what it shows you. Always connect with the seller to guarantee compatibility.
von
I haven't been able to confirm that board will indeed fit. All responses from sellers were "not sure". That said, I just ordered a cheap reflow machine and am trying to figure out which USB-C female connector to get. From a video on YouTube out of central Asia, I looked at a repair on an Edge 30 pro, which seems mostly to be like my phone. It looks like that USB connector has 18 pins. So you know what a PN for.that connector would be? All I see so far are 16 pin and Motorola has been no help.
von
What is the correct part number for the charging port board (for XT2201-3)? I have the same issue and cannot get a good source to answer this.
Thanks
Bewertung 0
Hello,
I had this same issue where I couldn't find part. Moto Edge X30 is the international version of this phone and I got it at Aliexpress.
Bewertung 0
MO02703 I just ordered this part! I will update after I get it installed
Bewertung 0
Antwort hinzufügen
Rey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 44
Insgesamt: 1,138
