Can this iPhone 5c be recovered?
I found my old iphone 5c it looks like it had some water damage and the screen was cracked. I remember about 8 years ago i dropped it and the screen stopped working. I was able to remove the screen and it is it a little rusty. Is it worth it trying to recover it I did have some photos i didnt get to save. I bought a new screen and battery hoping it could at least power on. I also accidentally cut the top ribbon under the battery but the bottom one is still connected Any thoughts?
Ist dies eine gute Frage?
Pictures would help us understand the damage done a bit better letting us give a better diagnosis. First step however is to make sure the motherboard is clean and doesn't have any corrosion or other damage. A bit of isopropyl alcohol and a brush should do the trick if there is any. Depending on damage ofcourse.
Bilder zu einer vorhandenen Frage hinzufügen
https://www.replacebase.eu/esd-safe-anti...
von Markus Norstrøm
Just added some now. I was able to power the phone on for a brief moment and then it shut down and has not turned on. It has been on a charge for the past 30 minutes.
von Coach B
@coachb6185 you would need to try a new charge port, chances are the board has damage aswell due to the amount of rust around the rest of the logic board
von daniel
