Zum Hauptinhalt wechseln
Sony digital camera in the Cyber-shot series. Shoots 6 MP photos and is released in 2006.
Lens is stuck halfway
My Sony DSC-H2 was working fine until recently. The word 'Access' appears when you start it up, indicating that there's a problem with extending the lens. The image is fuzzy and can't be focused. When I try to power it off, it tries about three times to retract the lens but then gives up and leaves the lens half out.
I've tried new batteries and a factory reset of the camera.
Any help appreciated.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Tengo una de este tipo y le dieron un golpe y al encender el lente no trabaja no enfoca
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@randominion7494 your camera has a stuck lens. Try the tips fromthis site If none of that works, you may have to replace the lens. To work on it use this teardown Sony Cyber-shot DSC-H2 Teardown and the Sony instructions right here DSC H2 Disassembly
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you for your suggestion.
von
Antwort hinzufügen
randominion wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 111
