Zum Hauptinhalt wechseln
Modell A1136 mit 30, 60, oder 80 GB Festplatte / Front aus schwarzem oder weißem Kunststoff.
798 Fragen Alle anzeigen
Sometimes my iPod starts with sad iPod support screen?
My 5th Gen 30gb iPod works great; except now after it's been off with the hold switch on for a long time it starts with the sad iPod support screen. If I do a reset it will start-up fine and work great. I can turn it off set the hold switch throughout the day and it starts just fine, but when I do the same thing at night the next morning its starts with the sad iPod screen again. I have noticed that when this happens I do not hear the HD spinning like I do after a reset or a normal start-up. I had the battery replaced by a pro a year ago and it still holds a good charge, and I have had no problems with my PC or iTunes either. Help, any ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
shaddock4, it does sound like your HDD is getting sticky. It does happen with the older drives and will eventually lead to failure. I would start thinking about replacing the drive as well as the cable.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thanks oldturkey0, I guess I'll start shopping for a new HD and connector cable!
von
Thanks for accepting my answer. the drives are relatively easy to find on places like tvc-mall.com or alibaba.com Good Luck
von
i recommend installing a CF card(32GB) ona a ZIF to CF conveerter board, and wrap in tape so it dosen't short out, this is cheaper and more reliable
von
Antwort hinzufügen
shaddock4 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 342
