Zum Hauptinhalt wechseln
Reparaturanleitungen, Support und Infos zur Fehlerbehebung fĂĽr das erste 13" MacBook Air mit Apples ARM-basiertem M1 SoC (mit 8-core CPU und bis zu 8-core GPU). Erschienen im November 2020 und identifiziert mit den Modellnummern A2337 und EMC 3598.
Blank screen w/ backlight after replacement - MacBook Air 13"
Hello,
I have a Macbook Air M1 2020 and I have replaced the full display. But after the replacement, the screen does not show anything.
  • I can see that there is a backlight and the screen responds to the brightness control buttons.
  • I can have video when connect it to an external monitor.
  • In System Settings -> Display, the macOS recognizes the built in monitor.
  • The camera is working fine.
Does anyone have an idea if I have missed any step? Or if it can be an hardware issue?
Thank you in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
I have this exact same problem. I replaced the display, and it's staying black. The backlight works, it recognizes it when connected to an external display, the camera works, etc. Therefore, I'm fairly sure that the display is connected properly. So I guess that it's just a bad display?
von
@ravenclaw900 Yes, I have replaced the display and it worked now.
von
@vinicius74976 - Happy to hear your display issues are resolved. Please score and accept the answer. Thanks!
von
Einen Kommentar hinzufĂĽgen
1 Antwort
Gewählte Lösung
Where did you get the replacement display? Is it possible you put the bad one back in? If you are sure then it sounds like you got a bad one. Review this guide steps to see if you missed something MacBook Air 13" (Ende 2020) Display tauschen
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufĂĽgen
Vinicius wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 108
