Zum Hauptinhalt wechseln
Reverse osmosis units are common water filtration solutions found under sinks in kitchens.
My purifer unable to fill water in its tank?...why?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
@sehajarora80537 let us know if you have a make and a model for this. You also want to post some pictures of your setup. Let's see what you got going on there. Bilder zu einer vorhandenen Frage hinzufügen
Mine uses a prefilter that require frequent changing. I clean mine every 3 months of use with food grade citric acid.
von
Einen Kommentar hinzufügen
1 Antwort
Likely calcium build up in the lines.
If you can, push a straightened metal coat hanger thru the fittings and pipes or use a calcium cleaner within a bucket to soak the fittings and pipes. Make sure to fully rinse off the cleaner from the parts and let the water run a bit before using.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
sehaj arora wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 166
