It's usually one of 3 common reasons on these older HP lasers. Either a bad toner, bad fuser or laser issue where it is degraded or dirty.
First thing I always try when it's borderline is I'll replace the toner, even if it's reman; a lot of the time, it's some imaging component issue in the toner cart from age, but not always. Either way, these are cheap enough for old models (hint: I pay $25 for 2 80X compatibles for my M401).
If the issue remains with a new toner, do a "halfway test": do a test page and stop it mid-run to see if a bad fuser is introducing the issue. If it's perfect before you get to the fusing unit, the fuser is the culprit; it isn't getting hot enough to melt the toner due to the lamp wearing down. But be mindful of what you pay for the fuser and where you buy it. You want a used low PC fuser (dead formatter or it's on the way out, or someone who knows these parted it out because nobody who knows better tries to rehab the p2015) or a good rebuild. Don't put a junk fuser in these -- it will suck to replace a 2nd time!
CAUTION: The fuser on the P2015 is a nightmare to replace -- later models like the P2055 and M401 simplified it (at the expense of the printer's footprint, which is still good), but it's not a 5-minute job. This printer requires all 3 panels (top and sides) to come off, then you need to take a few parts of the frame off. No guide on this here yet, but it's deep inside this series :-(
This model is also prone to formatter board failures as it ages due to bad lead-free solder quality, but many of them died young; the surviving machines may be fine, but it's such a well-known issue that anyone who can work on a deep printer issue like this throws these to the side as if they're like surprise kids which come with a new relationship unless they're low PC uncorns. Most of the time they have 100k+ pages and need parts like rollers or were dumped due to the early warnings of an impending formatter board failure.
If the issue is not with the fuser, take the laser apart and see if there is any degradation of the mirror assembly coatings or toner penetration from several years of use; if it builds up enough, it will kill your print quality. You can take the laser out similarly to the fuser; it's just in the top area and a sealed box you need to dismantle. Beyond the plastic panels, not much is needed to get to it.
CAUTION: IF YOU TRY AND CLEAN THE LASER, DO NOT BUMP THE SPINNING MOTOR OR TOUCH THE LASER REFLECTOR; only clean the mirrors and acrylic reflectors. I would also strongly caution you to buy a pack of new virgin microfibers -- please. You want this perfect, meaning you'll also want to blow it out until it is borderline spotless; small dust is fine, but the mirrors CANNOT BE SMUDGED. This also has the very real potential to theoretically make the printer worse with no way to undo the damage!
ONLY TRY THIS AS A LAST RESORT AND CONFIRMING YOU CAN QUICKLY PURCHASE A NEW PRINTER (see below for what I generally recommed today).
This laser came off of a color laser, but the same principles apply.
Red= no touch
Green= virgin microfiber safe
If the issue is still present with these checks, it is likely with something serious like the power supply. However, much like the laser, it's more to fix than the printer is worth, and it's arguably a much more awful repair to do even compared to the fuser.
If it comes down to this being beyond repair and you've checked the "easy" things, do yourself a favor and buy a new Canon laser printer or an older HP from 2012 like the M401 series (being mindful of the PC on the M401, which is 10+ years old, and potentially having to replace the paper pickup rollers and separators if it has ~20k pages when you get it).
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
