Zum Hauptinhalt wechseln
Guides and repair information for washing machines produced by GE, an engineering and technology company in the US.
20 Fragen Alle anzeigen
GE washer won’t turn on
Hi guys, I’m having a bit of trouble with my GE washing machine (Model wcse4160b1ww). In mid-cycle it died; no power in the machine. Tried all the obvious steps and am stuck. Thank you
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @shingle,
I don't know if it is regarded as being obvious but it looks like there's a wiring diagram, shown folded up in the 1st control panel image you posted above. ;-)
If it is check if it shows where the AC input comes into the machine.
It may be either a control board or a display board issue - looks like a LV power transformer on the control board is used to supply the voltage to operate the various relays and most likely the display board - so you could check if power is getting to the board and the transformer then perhaps there may be a fuse etc on the other side of the board(s).
The mini manual for the washer is GE p/n 31-15484 but I can't find it online- free or otherwise
If you find the problem and it is a faulty part, here's a parts list that is useful as it shows the manufacturer's part number for all the parts. Search online for the part number to find suppliers that suit you best.
Cheers
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
shingle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 97
