Zum Hauptinhalt wechseln
The Kobo Glo HD is an e-reader produced by Toronto-based Kobo Inc. released on 1 May 2015.
4 Fragen Alle anzeigen
kobo glo HD with frozen screen
I have a Kobo Glo that froze the screen with the image of a book cover and doesn't do anything.
I've tried pressing the power button for 15 seconds, pressing the reset hole with a needle and it remains the same.
It's not even detected when I connect it to the computer.
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare:
I have the same problem, with an Kobo Aura. It is not responding to touch. Can this be repaired?
von
I had the same thing happen to my Kobo Glow. No response from any switches even after charging overnight. Not recognized by the PC either.
Here's what I did to fix it:
I followed the instructions found here to access the battery connector.
Kobo Glo HD eReader Akku Austausch
I only unplugged the battery for ~30 seconds, then reconnected. I DID NOT REMOVE THE BATTERY.
Power switch works and I can use my Kobo Glow again!
Hope this helps someone.
von
Einen Kommentar hinzufügen
1 Antwort
Hi,
In order for the kobo to be functional/restarted or detected when connected to computer, it needs to have sufficient battery power.
Try checking the charge port for fluff or debis and cleaning if necessary (look up how to on web) then check by using another charge cable.
Once you have confirmed that the device is charging leave it on charge for at least an hour.
If you cannot get the device to charge then you either have a depleted battery that won’t take charge or the charge port is faulty and needs replacement.
Hope this helps
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
vanda mota wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 24
Insgesamt: 123
