Zum Hauptinhalt wechseln
Digital Still Camera series W330 model of Sony Cyber-shot Cameras released in 2010. 14.1-megapixel, 4x optical zoom, 3.0˝ LCD.
6 Fragen Alle anzeigen
Why is my screen white?
So, I cracked my LCD a while back so I ordered a replacement off of eBay. I just replaced it, and I was testing it and the screen is white. When I turn my camera on, the lens opens but then retracts and the screen stays on. I was pretty gentle when I was replacing it, and the only reason why I replaced the old LCD was because it was cracked.
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare:
Just tested my old LCD and it doesn't turn on at all. I'm guessing I messed something up >:(
von
@ellasimones not necessarily. Try you new screen again and see if it still shows white.
von
@oldturkey03 tried it as well and same thing :(
von
Einen Kommentar hinzufügen
1 Antwort
@ellasimones so it remains black no matter what (old or new screen)? The white light means that your LCD receives the backlight but no video signal. So you'll have to check the connector where the LCD plugs in and check for bend, broken, corroded pins etc.
The backlight and the video have separate circuits. For the video processing you would have to check the IC201 which is the signal processor on the on the SY-243 board.
Basically what you want to do for now is to disassemble your camera and check the board for anything odd (missing or burned) component.
You can always post some pictures of that board with your Question so we can assist you with that. Bilder zu einer vorhandenen Frage hinzufügen
Also, you can now download the Level 2 and Level 3 SM from the bottom of this page Sony Cyber-shot DSC-W330. It'll help you with finding the components as well as trying to fix it.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
ellasimones wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 19
Insgesamt: 59
