Zum Hauptinhalt wechseln
Reparatur-, Demontage- und Fehlerbehebungsinformationen für das Microsoft Surface Pro 11. Das Gerät wurde im Juni 2024 mit der Modellnummer 2076 veröffentlicht.
What else do I need to change the case?
I have the Lower Case in my cart, but I am unsure what else i need to purchase from ifixit to put the surface back together?
Also do you really need (Ruck Plates of 9 kg + 9 kg + 14 kg ) like the microsoft document says?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @greel
If you're replacing the LCD panel then to ensure that it bonds correctly with the frame enclosure, you need the ruck weights distributed as shown in the service manual (see p.35→p.36) to make sure that does.
Alternatively you can use a Shot bag filled with steel shot, not sand, to ensure proper weight displacement. Using this is also shown in the manual, on the same pages.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Surface Pro 11 OLED Lower Case - Genuine
Im just replacing the case. I was assuming i could reuse the screen. Do i need a new screen too?
von
@greel
The part you linked looks like the lower case only i.e. where the motherboard is located and not the lid cover where the display is.
As for whether you need a new screen would depend on if the display works now or not.
von
Antwort hinzufügen
Alex Hernandez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 415
