Zum Hauptinhalt wechseln
2,3GHz, 2,6GHz oder 2,7GHz Quadcore Intel Core i7 Prozessor (Turbo Boost bis zu 3,7GHz) mit 6MB geteiltem L3 Cache.
Need help with with the right SSD Enclosure/Adapter
I need help with hardware compatibility for an SSD enclosure. The one I bought isn't correct, though the listing said it was only either 2.5 or 3.5. This is what I bought: https://www.amazon.com/dp/B0C73VYQCW?ref...
If it is right I can't see how it fits. Can you please point me to the right one, maybe just an adapter since I won't need durable use. Thanks for your kind reading.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The storage drive in the Retina 2012 15-inch MacBook Pro is not a 2.5 or 3.5 inch drive, its a specialized blade SSD. This is the enclosure you want (as far as I know they're only made by OWC).
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Will do Zach. Many thanks!
von
Antwort hinzufügen
Pamela Wilson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 85
