Zum Hauptinhalt wechseln
Reparaturanleitungen und Teardown-Informationen für das 14" MacBook Pro, das im Oktober 2021 veröffentlicht worden ist. Es verfügt über die neuen M1 Pro und M1 Max Chips von Apple. Modellnummer A2442.
Three second boot loop
Hi there, I have a 14" MacBook Pro (2021) that starts up when connected to charger, but then restarts after 3 seconds, and repeats the cycle indefinitely. When disconnecting the "battery board data cable" it starts up perfectly fine being connected to the charger only.
Is this a clear sign that the battery board/battery is faulty, or could it also be that there is an issue with the main/logic board? I don't want to replace the battery just to find out that there is something wrong with the logic board. That would be very sad.
Thank you!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Did you review this guide: MacBook Pro (14 Zoll, 2021) Akku tauschen taking note of the BMU cable connections and the cable it’s self. I’m suspecting you need a new BMU cable as this one is likely damaged.
Battery management unit (BMU) flex cable P/N 923-06765
I would also install CoconutBatteryso you can see more clearly what’s happening.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Eric wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 138
