Zum Hauptinhalt wechseln
Reparatur von LED-, Glühbirnen- und anderen tragbaren elektrischen Lichtquellen.
27 Fragen Alle anzeigen
Where can I get a battery holder for my Rayz LED Flashlight?
The only thing broken on this flashlight is the cheap-o metal part that makes contact with the battery. There is a 3-AAA battery holder the inserts inside the little flashlight.
The switch is a pushbutton on the bottom
I just need to replace the 3-AAA battery holder.
Where is a good source for these parts?
Thanks
Frank
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I couldn't find any replacements parts for this but I looked at mine. If you're talking about the plate that makes contact with the spring, consider replacing with a copper penny (pre 1982) and some solder. Maybe a silver dime (pre 1964) if the penny is to large.
War diese Antwort hilfreich?
Bewertung 5
1 Kommentar:
If the 3AAA battery holder is broken you can get a replacement from Dorcy. http://www.dorcydirect.com/c-19-flashlig...[pagenum=2*Sort=4*ava=0]
You will have to figure out which holder fits your flashlight, as they are not all the same. If your holder is the standard 3AAA holder with no "special" features I would look at 41-8046.
Good luck,
Joe
Bewertung 0
2 Kommentare:
I have one that has the same connectors as the lightbulb section and unable to remove either does this mean its a rechargeable and if so where can I find the charging base and the screw on bottom battery holder
von
Its a rayz brand btw
von
Antwort hinzufügen
040304 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 3,938
