Zum Hauptinhalt wechseln
The Motorola Atrix 4G is dual-core Android-powered phone by Motorola. Model Number: MB860.
28 Fragen Alle anzeigen
The glass on the top is cracked but still works what works?
Only the top glass is really bad cracked still works but the glass is sharp what do i look for to replace and how much will it cost?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
tbates107, here is my answer from a very similar question "the digitizer (touch screen) is available at places like this.For the repair itself, check this repair video" Hope this helps, good luck
War diese Antwort hilfreich?
Bewertung 1
It gonna cost you about $42 to $53 and Atrix 4G front screen digitizer is available at Amazon. This link can take you directly to the product if you wish to from Amazon.
Before purchasing make sure that you're going to get the panel glass also. Since your digitizer is just fine, what you will need most is the glass. Some sellers are just selling Digitizer only. So be careful.
Once you get the glass panel, you will visit YouTube and see step by step video guide to fix it on your own. If the glass panel is not available at Amazon, you can try eBay as well. Cheers!
Bewertung 1
Antwort hinzufügen
tbates107 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 700
