Zum Hauptinhalt wechseln
Die MacBook Familie entstand im Jahr 2006 und ersetzte das iBook als Consumer Laptop.
3787 Fragen Alle anzeigen
Frage geschlossen
best tools and screwdrivers to use
which screwdrivers are best to use to repair MacBooks? I've seen some in repair videos on various macbook repairs and upgrades and they were the right size but had a magnetic tip. the last upgrade i did, i really could have used a magnetic tipped driver. is the one ifixit sells have a magnetic tip or do you know where i can get some good ones? (thats not to say ifixits aren't good)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
This is really a sweet little kit, I've put mine together over the last year: [verlinktes Produkt fehlt oder ist deaktiviert: IF145-072]
Choice of tools is kind a matter of how deep your pockets are and just how professional you want get. For most repairs the 54 piece set is excellent: [verlinktes Produkt fehlt oder ist deaktiviert: IF145-022]
The $300 Professional set is something I'd like to get: [verlinktes Produkt fehlt oder ist deaktiviert: IF145-114]
I really like the 26 bit driver set because of the larger diameter driver (it allows for much more torque). [verlinktes Produkt fehlt oder ist deaktiviert: IF145-028] All these are magnetized when using the drivers. I'm sure iFixit could put together exactly what you need if you tell them exactly what you intend to work on and how much you have to spend on tools. Even an excellent box to keep them in: [verlinktes Produkt fehlt oder ist deaktiviert: IF145-129]
War diese Antwort hilfreich?
Bewertung 4
Well I'm not sure why ifixit is so over priced on the moody tools. $300 is ridiculous when you can get the same exact set for $170 on Amazon.
Bewertung 2
Ifixit sells exactly what you are looking for yes. You can purchase the tool bit set separately or go even as far as the Pro-Tech Base Toolkit. They even have a magnetizer/demagnetizer if what you receive isn't good enough.
Bewertung 0
The [verlinktes Produkt fehlt oder ist deaktiviert: IF145-022] works well and has magnetic tips. For 24.99, you can't beat it.
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 13,597
