Zum Hauptinhalt wechseln
Der iMac G5 hat den PowerPC G5 Prozessor, dieser wurde erstmals im August 2004 veröffentlicht.
20 Fragen Alle anzeigen
Shuts down shortly after starting.
When starting up, whole machine, and display, shuts down within several seconds to a few minutes. Sounds like a power supply, but notes I find about various EMC numbers don't include mine -- EMC # 2056. Any hints to identify any other cause than power supply?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Use the information in this Question, apart from the screen size the procedure would be the same.
If this answer was helpful please remember to return an mark it Accepted.
War diese Antwort hilfreich?
Bewertung 1
this is your machine
sounds like an overheating issue...when you've got the back off the machine you'll be able to see how much dirt and grime is in the fans and vent. Get the vacuum out see if you can clean the vents and fan. When you plug in the mains and turn the machine on (either bridge the 2 pins bottom left with a screw driver or use the reset button (has a power circle symbol next to it)) which LEDs light up on the motherboard? the 4th lights up red when it overheats. Take a good look at the capacitors and see if any are bulging... it's a common occurence with these machines.
After almost 10 years the thermal paste should be good and dry and it's always a good idea to replace it when you've opened up the Mac...(1 lot is under the G5 heat sink(need to unscrew it from the rear of the board), the other is located on the rear of the motherboard.
Bewertung 1
Antwort hinzufügen
david G wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,753
