Zum Hauptinhalt wechseln
Aufpolierte Version des iPhone 3GS mit schnelleren Verarbeitungsgeschwindigkeit. Die Reparatur geht ähnlich wie beim 3G vonstatten und braucht nur einfache Schraubendreher und Hebelwerkzeuge. Modell A1303 mit 16 oder 32 GB Kapazität mit schwarzer oder weißer Kunststoffrückseite.
1500 Fragen Alle anzeigen
Dock Connector Causing no Power or MB?
HI,
So my water damaged iPhone came today, and I figured I would go with the water damage repair with the IPA. But, upon further investigation, the water damage dots on the MB shields and in the headphone jack are both white. The dock connector board one is red. I bought it water damaged from a phone repair company (didn't notice that until I bid...). It won't charge, won't come on. It has a new battery, and it appears as if the shields have been removed to do the IPA treatment, as the "band-aid" sticker thing that goes over both shields is missing.
Should I replace the dock connector, or should I clean the MB first? I figure if I choose wrong, I either waste money on a part I don't need, or damage the MB further.
Thanks
--Corry
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hey Correy,
As long as you allow the MB to completely dry after soaking it in IPA, you shouldn't have any risk of damaging it. Liquid damage mainly occurs when there is a drop on the board that causes a short. As long as there is no liquid on the board when you run power through it, you cannot further damage the device with IPA. I would thoroughly clean the device before purchasing/installing any parts.
Hope this helps. Good luck!
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Will do, thanks
von
Antwort hinzufügen
Todd wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 336
