Zum Hauptinhalt wechseln
13" Aluminium Unibody, 2,0 oder 2,4 GHz Core 2 Duo Prozessor.
574 Fragen Alle anzeigen
Can I upgrade to a HDD with over 750 GB?
I currently have dual harddrives in my Macbook, but one is corrupt and needs to be replaced. Is it possible to upgrade to a 1TB harddrive? I ask because in under the Upgrades section of the Unibody Macbook it says you can only upgrade up to 750 GB, but I haven't been able to find any backup sources and it just doesn't make sense to me why it can only take 750 GB.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
YES - You are correct in your thinking any 2.5-inch drive with a Serial ATA (SATA) (3GB/s) connector.
''If this answer was helpful please remember to return an mark it Accepted.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Successfully installed a 1TB HDD. Thanks!
von
Antwort hinzufügen
Nick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 598
