Foam and Felt Filters
2 Antworten 3 Punkte |
Vacuum suction ok but green light won’t turn on and brush doesn’t spin |
1 Antwort 0 Punkte |
O-ring broke - does anyone have o-ring specifications? |
1 Antwort 1 Punkte |
My Vacuum is Plugged in but will not turn on |
2 Antworten 0 Punkte |
1st power press does nothing, 2nd setting spins brush but no suction |
Werkzeuge
Es werden ein paar gängige Werkzeuge verwendet, um an diesem Gerät zu arbeiten. Du wirst nicht jedes Werkzeug für jeden Schritt benötigen.
Background
The Shark Navigator Lift-Away Deluxe NV360 model is part of Shark Clean's Navigator Lift Away line up. It is a 1200 watt vacuum cleaner made by Shark. It weighs 12.5lbs and measures 15 by 11.4 by 45 inches. One of its distinctive features is the dust cup, which makes the vacuum bagless. It also features a HEPA filter, which helps minimize allergens with its anti-allergic complete seal technology.
The NV360 model includes a 5.5 inch crevice tool, a dusting brush, pet power brush, accessory holder, and appliance wand. It also has an unretractable 25ft power cord, but no rechargeable battery. Shark Navigator Lift-Away Deluxe has swivel steering to help with maneuvering. Another one of the features of the NV360 is the Lift-Away function. This function makes the vacuum modular, meaning people can use it as an upright vacuum or lift it away from the base for use as a portable vacuum. It has above-floor cleaning via the accessories as well as several modes of floor cleaning via the power button settings activating or deactivating the roller brush.
Identification
The Shark Navigator Lift-Away Deluxe comes in blue, black, and purple. However, they have different model numbers. The other models in the Navigator Lift-Away Series, such as NV370, NV355, NV391, NV356e, NV350, NV352, UV440, and UV490CCO, are either a different size and color or have different attachments and accessories, but their overall vacuum designs are similar to NV360.
Common Replacement Parts
Part | Part Number |
Pre-Motor Filter Set | XFF350 |
HEPA Filter | XHF350 |
Dusting Brush & Crevice Tool | 112FFJ |
Pet Power Brush | 119FFJ |
Appliance Wand | 120FLI360 |
