Zum Hauptinhalt wechseln
HP ProBook 640 G2 Battery Replacement
Was du brauchst
  1. HP ProBook 640 G2 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop so the bottom is facing up.
    • Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
    • Use a Torx T9 screwdriver to remove the single 6 mm screw.
    Frag FixBot
    Kommentar hinzufügen
  2. HP ProBook 640 G2 Battery Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to carefully pry the bottom case.
    • Insert the end of the opening tool into the seam between the bottom and top case and slide it around the perimeter to release the clips.
    • Remove the bottom cover.
    Frag FixBot
  3. HP ProBook 640 G2 Battery Replacement: Schritt 3, Bild 1 von 3 HP ProBook 640 G2 Battery Replacement: Schritt 3, Bild 2 von 3 HP ProBook 640 G2 Battery Replacement: Schritt 3, Bild 3 von 3
    • Use a JIS J1 screwdriver to remove the seven 6 mm screws securing the battery.
    • Lift the battery from the bottom edge and slide it out of the socket on the motherboard.
    Frag FixBot
Abschluss
Note - Be sure to dispose of your old battery responsibly! Check out iFixit's Guide on Recycling E-waste.
For optimal performance, calibrate your newly installed battery after completing this guide.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 52
Insgesamt: 287
