Zum Hauptinhalt wechseln
HTC Vive Focus Rear Head Strap Replacement
Was du brauchst
  1. HTC Vive Focus Rear Head Strap Replacement, Unscrew the head strap mounts: Schritt 1, Bild 1 von 2 HTC Vive Focus Rear Head Strap Replacement, Unscrew the head strap mounts: Schritt 1, Bild 2 von 2
    • Use a T6 Torx screwdriver to remove the four 4.6 mm screws securing the rear head strap, two on each side.
  2. HTC Vive Focus Rear Head Strap Replacement, Disconnect the rear head strap: Schritt 2, Bild 1 von 3 HTC Vive Focus Rear Head Strap Replacement, Disconnect the rear head strap: Schritt 2, Bild 2 von 3 HTC Vive Focus Rear Head Strap Replacement, Disconnect the rear head strap: Schritt 2, Bild 3 von 3
    • Remove the plastic cover from the rear head strap mount.
    • Lift the rear head strap off of the two pegs securing it to the mount.
    • Repeat for the remaining side of the rear head strap.
    • During reassembly, be careful not to install the rear head strap upside-down. The adjustment knob on the back of the head strap should be on top.
  3. HTC Vive Focus Rear Head Strap Replacement, Remove the rear head strap: Schritt 3, Bild 1 von 1
    • Remove the rear head strap.
Abschluss
Sam Omiotek
73.693 Reputation
288 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 170
