Zum Hauptinhalt wechseln
HTC Vive Pro Headphone Replacement
Was du brauchst
  1. HTC Vive Pro Headphone Replacement, Remove the head strap padding: Schritt 1, Bild 1 von 3 HTC Vive Pro Headphone Replacement, Remove the head strap padding: Schritt 1, Bild 2 von 3 HTC Vive Pro Headphone Replacement, Remove the head strap padding: Schritt 1, Bild 3 von 3
    • Peel off the thin piece of padding covering the headphone screw for each headphone you are replacing.
  2. HTC Vive Pro Headphone Replacement, Unscrew the headphone(s): Schritt 2, Bild 1 von 2 HTC Vive Pro Headphone Replacement, Unscrew the headphone(s): Schritt 2, Bild 2 von 2
    • Use your Phillips screwdriver to remove the 6.4 mm screw securing each headphone you are replacing.
  3. HTC Vive Pro Headphone Replacement, Remove the headphone(s): Schritt 3, Bild 1 von 3 HTC Vive Pro Headphone Replacement, Remove the headphone(s): Schritt 3, Bild 2 von 3 HTC Vive Pro Headphone Replacement, Remove the headphone(s): Schritt 3, Bild 3 von 3
    • Remove the headphone(s).
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sam Omiotek
73.603 Reputation
288 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 52
Insgesamt: 1,326
