Zum Hauptinhalt wechseln
MacBook Pro 15" Core Duo Model A1150 Akku tauschen
Was du brauchst
    1. MacBook Pro 15" Core Duo Model A1150 Akku tauschen, Akku: Schritt 1, Bild 1 von 1
      • Ziehe mit deinen Fingern beide Laschen vom Akku weg und hebe den Akku aus dem Computer heraus.
      Frag FixBot
      Kommentar hinzufügen
Abschluss
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
132 weitere Personen haben diese Anleitung absolviert.
en de
100%
Hier starten ›
3 Kommentare zur Anleitung
Hello,
I have found a really important mistype, on this page.
I assume, that on the picture, those tools are not thumbs but the "Introduction" says so!!! Those are "finger" tools.
It can mislead persons like me also, with my 25 years old of highly educated professional tool user experience.
Please correct the tools down below.
With the thumb tool, i was unable unattach the battery from the case.
BR
Albert Einstein - Antwort Teilen
Indeed, executing the detachment process of the battery using "thumbs" is a highly risky operation only to be performed by well-trained thumb specialists. The use of other "fingers" is much more common, as it might induce fairly less risk of severe injuries or death. Also, "Fingers" have a sweet little picture illustrating the right tool to use. I changed the guide accordingly.
marmuc100 - Antwort Teilen
Thank you so much gentleman for your help.
I appreciate the professional answer and the correction.
From now on i can sleep well at nights.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 73
Insgesamt: 118,533
