Zum Hauptinhalt wechseln
Polaroid Now+ (Gen 3) Film Shield Replacement
Was du brauchst
  1. Polaroid Now+ (Gen 3) Film Shield Replacement, Safety precautions: Schritt 1, Bild 1 von 2 Polaroid Now+ (Gen 3) Film Shield Replacement, Safety precautions: Schritt 1, Bild 2 von 2
    • If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
    • Before you begin:
    • Unplug and fully power down your camera.
    • Put on the lens cap to avoid scratching your lens during disassembly.
    Frag FixBot
    Kommentar hinzufügen
  2. Polaroid Now+ (Gen 3) Film Shield Replacement, Open the film door: Schritt 2, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Open the film door: Schritt 2, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Open the film door: Schritt 2, Bild 3 von 3
    • Throughout this guide, directional words (front, back, left, right) are from the perspective of using the camera—or when the lens faces away from you.
    • Hold down the latch on the left side of the camera and open the film door.
    Frag FixBot
  3. Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the rear shell screw: Schritt 3, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the rear shell screw: Schritt 3, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the rear shell screw: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $16.96
    • Use a Phillips screwdriver to remove the 5.9 mm‑long screw securing the rear shell.
    • The screw is hidden inside the camera on the back edge—you may need to use a flashlight to see it, as well as a skinny, long‑shank screwdriver to reach it.
    • Be careful when removing your screwdriver, as the screw can easily fall inside the camera. If it does, hold the camera above your work surface and gently shake it so the screw falls out.
    Frag FixBot
  4. Polaroid Now+ (Gen 3) Film Shield Replacement, Release the rear shell clips: Schritt 4, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Release the rear shell clips: Schritt 4, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Release the rear shell clips: Schritt 4, Bild 3 von 3
    • Insert the flat edge of an opening pick in the seam between the front and rear shells, just above the USB‑C port on the right edge.
    • Use your pick to pry the rear shell away from the front shell.
    • Keep the inserted edge of the pick pointed toward the rear shell when separating it. This helps release the tight plastic clips holding them together.
    Frag FixBot
  5. Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 5, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 5, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 5, Bild 3 von 3
    • You should feel and hear distinct "clicks" as the clips release. If you don't, try again—it may take multiple attempts.
    • Slide your pick around the top right corner and along the top edge to release the clips.
    Frag FixBot
  6. Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 6, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 6, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 6, Bild 3 von 3
    • Continue sliding your pick along the top edge, around the top left corner, and down the left edge to release the clips. Stop when you get to the film door latch.
    Frag FixBot
  7. Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 7, Bild 1 von 1
    • Gently flip the camera over, making sure none of the clips re‑engage.
    Frag FixBot
  8. Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 8, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 8, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 8, Bild 3 von 3
    • Remember to keep the inserted edge of the pick pointed towards the rear shell.
    • Insert your opening pick in the seam near the USB‑C port and slide it around the corner and along the bottom edge to release the remaining clips.
    Frag FixBot
  9. Polaroid Now+ (Gen 3) Film Shield Replacement, Camera mirror warning: Schritt 9, Bild 1 von 2 Polaroid Now+ (Gen 3) Film Shield Replacement, Camera mirror warning: Schritt 9, Bild 2 von 2
    • Removing the rear shell in the next step exposes the camera mirror. Be careful not to smudge it or get any debris on it. If you accidentally do, use a lint‑free cloth to gently wipe the mirror clean.
    Frag FixBot
  10. Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the rear shell: Schritt 10, Bild 1 von 2 Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the rear shell: Schritt 10, Bild 2 von 2
    • Gently pull the rear shell off the main body of the camera.
    • The shell should slide off easily. If it doesn't, check to see if any clips re‑engaged and use your opening pick to release them.
    • During reassembly:
    • Press the shell firmly onto the main body so all the clips engage.
    • You should feel and hear distinct "clicks" as the clips engage.
    • Check around the shell seam and make sure there are no gaps. If there are, firmly press the shells together to engage the clip near the gap.
    Frag FixBot
  11. Polaroid Now+ (Gen 3) Film Shield Replacement, Capacitor warning: Schritt 11, Bild 1 von 2 Polaroid Now+ (Gen 3) Film Shield Replacement, Capacitor warning: Schritt 11, Bild 2 von 2
    • The capacitor in your camera holds an electrical charge and can deliver a potentially dangerous electric shock if you touch the boards incorrectly.
    • To minimize risk, avoid touching the boards, wires, and other exposed components with your fingers or metal tools. Consider wearing rubber gloves if working near the board.
    Frag FixBot
  12. Polaroid Now+ (Gen 3) Film Shield Replacement, Flip your camera over: Schritt 12, Bild 1 von 1
    • Flip your camera over so the bottom is facing up.
    Frag FixBot
  13. Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the film door screws: Schritt 13, Bild 1 von 2 Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the film door screws: Schritt 13, Bild 2 von 2
    • Use a Phillips screwdriver to remove the two 3 mm‑long film door hinge screws (one on either side of the camera).
    Frag FixBot
  14. Polaroid Now+ (Gen 3) Film Shield Replacement, Insert a clean cloth: Schritt 14, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Insert a clean cloth: Schritt 14, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Insert a clean cloth: Schritt 14, Bild 3 von 3
    • Open the film door and place a clean cloth in the compartment.
    • This prevents the door from re‑securing while detaching the hinges.
    Frag FixBot
  15. Polaroid Now+ (Gen 3) Film Shield Replacement, Detach the film door: Schritt 15, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Detach the film door: Schritt 15, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Detach the film door: Schritt 15, Bild 3 von 3
    • The small, plastic grommets inside the film door hinges can easily fall off during this step. Don't lose them—you'll need them for reassembly.
    • Use the flat end of a spudger to push one of the film door hinges away from the camera and off its post.
    • Repeat the process to detach the other hinge.
    • Hold the film door steady so the already detached hinge doesn't slide back into place.
    Frag FixBot
  16. Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 16, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 16, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 16, Bild 3 von 3
    • Check to see if either of the small, plastic hinge grommets stayed on their posts.
    • If they did, remove them and set them aside.
    Frag FixBot
  17. Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the film door: Schritt 17, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the film door: Schritt 17, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the film door: Schritt 17, Bild 3 von 3
    • Lift the film door and remove it.
    • At this point, you can remove the cloth from the film door compartment.
    • Make sure there are grommets installed in the film door hinges. To install them, press the grommets into the film door hinges, with the wide end facing in.
    • Hook one of the hinges on its post and then push the other one into place until it snaps over its post.
    Frag FixBot
  18. Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the print roller screw: Schritt 18, Bild 1 von 2 Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the print roller screw: Schritt 18, Bild 2 von 2
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips screwdriver to remove the 3.9 mm‑long screw securing the print roller.
    • You may need to use a flashlight to see the screw, as well as a skinny, long‑shank screwdriver to reach it.
    Frag FixBot
  19. Polaroid Now+ (Gen 3) Film Shield Replacement, Unclip the print roller: Schritt 19, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Unclip the print roller: Schritt 19, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Unclip the print roller: Schritt 19, Bild 3 von 3
    • Two plastic tabs secure the center of the print roller.
    • Use the tip of a spudger to depress both plastic tabs until their hooks release from the print roller—you'll hear an audible "click."
    Frag FixBot
  20. Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the print roller: Schritt 20, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the print roller: Schritt 20, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the print roller: Schritt 20, Bild 3 von 3
    • Grab the print roller by one of its arms and pull it straight out of its plastic housing.
    • Pull straight away from the housing to avoid bending or warping the metal.
    • If you're having trouble, make sure the clips are released. You may have to hold the clips down while pulling.
    Frag FixBot
  21. Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 21, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 21, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement: Schritt 21, Bild 3 von 3
    • The print roller is a sensitive component. Be extremely careful during reassembly to not bend or warp the metal.
    • During reassembly, note the following to properly reinsert the print roller into its plastic housing:
    • Two metal L-shaped rails at the bottom of the print roller need to slide under cutouts in the plastic housing.
    • Two metal hooks at the top of the print roller need to fit under the top corners of the plastic housing.
    • Insert the print roller at a downward angle to fit the hooks in first before sliding the rails into place.
    • Push the print roller into its plastic housing until you hear the plastic tabs click back into place.
    Frag FixBot
  22. Polaroid Now+ (Gen 3) Film Shield Replacement, Unclip the film shield tray: Schritt 22, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Unclip the film shield tray: Schritt 22, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Unclip the film shield tray: Schritt 22, Bild 3 von 3
    • Two clips secure the center of the film shield tray.
    • Insert the tip of an opening pick between one of the outer edges of the film shield tray and the plastic housing.
    • Slide your opening pick along the film shield tray to release the clips—you should feel and hear distinct "clicks" as the clips release.
    Frag FixBot
  23. Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the film shield tray: Schritt 23, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the film shield tray: Schritt 23, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the film shield tray: Schritt 23, Bild 3 von 3
    • Pull the film shield tray out of its recess and remove it.
    • To avoid damaging the film shield, first insert the long edge with an angle into the recess before pushing the tray into place. The side with cutouts should be facing up.
    • Push the film shield tray into place until you feel and hear the clips click into place.
    Frag FixBot
  24. Polaroid Now+ (Gen 3) Film Shield Replacement, Unhook the film shield: Schritt 24, Bild 1 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Unhook the film shield: Schritt 24, Bild 2 von 3 Polaroid Now+ (Gen 3) Film Shield Replacement, Unhook the film shield: Schritt 24, Bild 3 von 3
    • The film shield sits on four alignment pegs.
    • Use the point of a spudger or tweezers to carefully lift the shield off its pegs.
    • During reassembly, align the film shield over its pegs and a use spudger to gently press it into place.
    Frag FixBot
  25. Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the film shield: Schritt 25, Bild 1 von 2 Polaroid Now+ (Gen 3) Film Shield Replacement, Remove the film shield: Schritt 25, Bild 2 von 2
    • Pull the film shield out of its slot in the plastic housing and remove it.
    • During reassembly, insert the film shield into its slot so the flat section with cutouts is on top.
    Frag FixBot
Abschluss
Spencer Day
191.426 Reputation
1.204 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.947 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 49
Insgesamt: 336
