Zum Hauptinhalt wechseln
Razer Blade 14'' (2017) Battery Replacement
Was du brauchst
  1. Razer Blade 14'' (2017) Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Razer Blade 14'' (2017) Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Razer Blade 14'' (2017) Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Power off the laptop.
    • Use the T5 Torx screwdriver to unscrew the 10 screws found at the bottom of the laptop. Then, remove the back plate of the laptop.
    Frag FixBot
    Kommentar hinzufügen
  2. Razer Blade 14'' (2017) Battery Replacement: Schritt 2, Bild 1 von 3 Razer Blade 14'' (2017) Battery Replacement: Schritt 2, Bild 2 von 3 Razer Blade 14'' (2017) Battery Replacement: Schritt 2, Bild 3 von 3
    • At the bottom left corner of the battery, grab and pull the power indicator cable towards the left to disconnect it.
    Frag FixBot
  3. Razer Blade 14'' (2017) Battery Replacement: Schritt 3, Bild 1 von 3 Razer Blade 14'' (2017) Battery Replacement: Schritt 3, Bild 2 von 3 Razer Blade 14'' (2017) Battery Replacement: Schritt 3, Bild 3 von 3
    • At the top center of the battery, use the opening tool to flip the ribbon cable ZIF latch up.
    Frag FixBot
  4. Razer Blade 14'' (2017) Battery Replacement: Schritt 4, Bild 1 von 3 Razer Blade 14'' (2017) Battery Replacement: Schritt 4, Bild 2 von 3 Razer Blade 14'' (2017) Battery Replacement: Schritt 4, Bild 3 von 3
    • At the bottom center of the battery, use the opening tool to flip the ribbon cable ZIF latch up. (similar way from step 3)
    • Slide both ends out of the ZIF connector. Remove the touchpad ribbon cable that overlaps the battery.
    Frag FixBot
  5. Razer Blade 14'' (2017) Battery Replacement: Schritt 5, Bild 1 von 3 Razer Blade 14'' (2017) Battery Replacement: Schritt 5, Bild 2 von 3 Razer Blade 14'' (2017) Battery Replacement: Schritt 5, Bild 3 von 3
    • At the top right side of the battery, use the opening tool to disconnect the battery cable from the motherboard.
    Frag FixBot
  6. Razer Blade 14'' (2017) Battery Replacement: Schritt 6, Bild 1 von 2 Razer Blade 14'' (2017) Battery Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove all 7 screws.
    Frag FixBot
  7. Razer Blade 14'' (2017) Battery Replacement: Schritt 7, Bild 1 von 1
    • Remove the battery.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 19
Letzte 30 Tage: 112
Insgesamt: 3,838
