Was du brauchst
Remove the screw(s) securing the two dispenser panels.
Pull the dispenser panels straight down to separate them from the chassis.
Remove the dispenser panels.
Tilt the bottom of the control board away from the chassis to release its clips.
Pull straight down to separate the control board enough to access its connectors.
Disconnect the connectors attached to the control board.
Fast fertig!
Abschluss
