Zum Hauptinhalt wechseln
iPhone 4S Battery Replacement
Was du brauchst
  1. iPhone 4S Battery Replacement, Pentalobe Screws: Schritt 1, Bild 1 von 1
    • Remove the two bottom Pentalobe screws next to the 30-Pin connector.
    • It is recommended that you use a small 5-Point screwdriver for this process.
    • Remember to make sure your iPhone is fully turned off before commencing this process, to prevent serious injury to the phone.
    Frag FixBot
    Kommentar hinzufügen
  2. iPhone 4S Battery Replacement, Back Panel Removal: Schritt 2, Bild 1 von 2 iPhone 4S Battery Replacement, Back Panel Removal: Schritt 2, Bild 2 von 2
    • Push the back panel towards the top of the iPhone. Doing this should allow the back panel to slide off safely.
    • Do not apply too much pressure to the back. Especially if your phone has a cracked back panel.
    • Do not rush it! Time is key.
    Frag FixBot
  3. iPhone 4S Battery Replacement, Battery Screws: Schritt 3, Bild 1 von 1
    • Remove these two screws that are securing the battery connector to the Logic Board.
    • Beware of unscrewing the battery connector, as your screwdriver does have the possibility to slip and pierce the battery.
    • For the bottom screws, it is recommended that you use a 1.5 mm screw bit, and a 1.7 mm for the top screw.
    Frag FixBot
  4. iPhone 4S Battery Replacement, Battery Strip: Schritt 4, Bild 1 von 1
    • Locate and pull the plastic tab to pull out the battery. Make sure to pry up on the outside of the battery on all sides.
    • Do not pull on the plastic tab too hard, as it can easily rip, making the battery removal process harder.
    Frag FixBot
  5. iPhone 4S Battery Replacement, Battery Removal: Schritt 5, Bild 1 von 1
    • Carefully remove the battery.
    • Remember, if you are replacing your battery, remember to preform a hard reset on your iPhone by holding on both the home and power button for a few seconds once the repair is all finished.
    Frag FixBot
Abschluss
64 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
la olum bunu benim 1 yaşında kızım da biliyo
ahmetceylanbm - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 51
Letzte 30 Tage: 221
Insgesamt: 25,783
