Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
MacBook Air (Original-Mid 2009) Replacement Battery
  • MacBook Air (Original-Mid 2009) Replacement Battery / Fix Kit
  • MacBook Air (Original-Mid 2009) Replacement Battery / Part Only
69,99 $
69,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Nintendo Switch Kits
Eine schnelle Lösung, um wieder ins Spiel zu kommen
Switch Kits kaufen
Switch Kits kaufen
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook Air (Original-Mid 2009) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 5280 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your MacBook Air's lifespan, extend it with this new replacement battery compatible with MacBook Air (Original-Mid 2009). Factory-installed MacBook Air (Original-Mid 2009) batteries are rated to last 300 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Kompatibilität
Kompatibilität
  • MacBook Air 13" A1237 Original
  • MacBook Air 13" A1304 Late 2008 to Mid 2009
Eigenschaften
Eigenschaften
Part #:
661-4587, 661-4915
Model #:
A1245
Watt Hours:
37 Wh
Voltage:
7.2 V
Milliamp Hours:
5280 mAh
Manufacturer:
Aftermarket
Kompatibilität
MacBook Air Models A1237 and A1304
EMC 2142 1.6 GHz (Original)
EMC 2142 1.8 GHz (Original)
EMC 2253 1.6 GHz (Late 2008)
EMC 2253 1.86 GHz (Late 2008)
EMC 2334 1.86 GHz (Mid 2009)
EMC 2334 2.13 GHz (Mid 2009)
Kundenbewertungen
