Artikelbeschreibung
Beschreibung
This MacBook Pro 13" Retina Late 2013 to Mid 2014 replacement battery fix kit includes all the parts, tools, and adhesive you need to bring your dead laptop back to life!
- 100% factory tested.
- Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 6010 mAh.
- Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
- Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your laptop's lifespan, extend it with this new replacement battery compatible with Late 2013 to Mid 2014 MacBook Pro 13" Retina. Factory-installed laptop batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Kit Inhalt
- New Replacement Battery compatible with a MacBook Pro 13" Retina (Late 2013/Mid 2014) laptop
- Installation Adhesive
- iFixit Adhesive Remover
- Safety Glasses
- Nitrile Gloves (2)
- Berkshire PRO Wipe 880
- Spudger
- iFixit Opening Tool
- iFixit Opening Picks (Set of 6)
- Plastic Cards
- Angled Tweezers
- Precision Bit Driver
- 4 mm Precision Bits:
- Pentalobe P5
- Torx T5
- Torx Security TR6
Kompatibilität
- MacBook Pro 13" Retina A1502 Late 2013 to Mid 2014
Eigenschaften
Kompatibilität
Reparaturanleitungen
MacBook Pro 13" Retina Display Ende 2013 Akku austauschen
Schwierigkeitsgrad:
Schwierig
MacBook Pro 13" Retina Display Late 2013 Trackpad Austausch
Schwierigkeitsgrad:
Schwierig
MacBook Pro 13" Retina Display Mitte 2014 Akku austauschen
Schwierigkeitsgrad:
Schwierig
MacBook Pro 13" Retina Display Mitte 2014 Trackpad austauschen
Schwierigkeitsgrad:
Schwierig
MacBook Pro 13" Retina Display Mitte 2014 oberes Gehäuse austauschen
Schwierigkeitsgrad:
Schwierig
Kundenbewertungen
