Repariere deine Sachen
Recht auf Reparatur
Store
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.3 GHz Logic Board
  • MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.3 GHz Logic Board
  • 360°
360
149,99 $
149,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
Replace the logic board in your MacBook Pro 13" Unibody (Early 2011/Late 2011) and fix processing issues.
  • Included Ports: FireWire 800, Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot.
A corroded, malfunctioning, or water-damaged logic board can cause unexpected shutdowns or reboots. Restore the functionality of your device with this replacement part.
Kompatibilität
Kompatibilität
  • MacBook Pro 13" Unibody A1278 Early 2011 to Late 2011
Eigenschaften
Eigenschaften
Part #:
661-5869
Model #:
A1278
Kompatibilität
MacBook Pro 13" Unibody Early 2011
A1278 (EMC 2419) 2.3 GHz
A1278 (EMC 2419) 2.7 GHz
MacBook Pro 13" Unibody Late 2011
A1278 (EMC 2555) 2.4 GHz
A1278 (EMC 2555) 2.8 GHz
Reparatur-Geschichten
Nutzeravatar
fantastikot's Story Photo #179314
fantastikot's Story Photo #179315
fantastikot's Story Photo #179316
Mein Problem
Our early 2011 MBP 13" stopped charging the battery and eventually refused to stay on even when connected with the MagSafe power adapter. We took it to an Authorized Apple Specialist, they determined that water damage was the culprit. The solution was to replace the logic board for $900. AppleCare w . . .
Nutzeravatar
Mein Problem
Charger grounded, over current to logic board. Would not charge battery, fan ran on high. computer worked fine, just would not allow the battery to charge!
Meine Reparatur
New logic board.
Mein Rat
N/A
Nutzeravatar
Mein Problem
I bought this macbook off ebay and decided it would be a great way to get a working mac really cheap! only replaced the logicboard and mag safe connector and Bam ! worked great!
Meine Reparatur
very quick and easy. Excellent repair guide on your site made it a breeze!
Mein Rat
follow everything the guide book says ! every . . .
