MacBook Pro 16" (2019) Battery
  • MacBook Pro 16" (2019) Battery / New / Part Only
119,99 $
119,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook Pro 16" (2019) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 4370 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
Battery degradation is an inevitable part of your laptop’s lifespan, extend it with this new replacement battery compatible with the 2019 MacBook Pro 16". Factory-installed MacBook Pro batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Kompatibilität
Kompatibilität
  • MacBook Pro 16" A2141 2019
Eigenschaften
Eigenschaften
Watt Hours:
18.74 Wh
Voltage:
4.43 V
Milliamp Hours:
4855 mAh
Manufacturer:
Aftermarket
Kompatibilität
MacBook Pro 16" 2019
A2141, EMC 3347, Core i7 2.6 GHz, AMD Radeon Pro 5300M, MacBookPro16,1
A2141, EMC 3347, Core i7 2.6 GHz, AMD Radeon Pro 5600M, MacBookPro16,4
A2141, EMC 3347, Core i9 2.3 GHz, AMD Radeon Pro 5500M, MacBookPro16,1
A2141, EMC 3347, Core i9 2.3 GHz, AMD Radeon Pro 5600M, MacBookPro16,4
A2141, EMC 3347, Core i9 2.4 GHz, AMD Radeon Pro 5300M or 5500M, MacBookPro16,1
A2141, EMC 3347, Core i9 2.4 GHz, AMD Radeon Pro 5600M, MacBookPro16,4
Kundenbewertungen
