Zum Hauptinhalt wechseln
« Zurück zu allen Geschichten
Ipod classic gen 3
Andrew O'Brien -
iPod 3rd Generation
Bild zur Geschichte
  • Bild #1
  • Bild #2
  • Bild #3
iPod 3rd Generation Battery Replacement
30 Minuten
Moderate
Mein Problem
my ipod would not charge, turn on, or hold a charge. Whenever it was plugged in, the iPod would display the apple logo then flash off. The battery was bad.
Meine Reparatur
I recieved the battery replacement kit one day early, and got right to work. Popping apart the iPod was the hardest part of the whole repair, with not breaking the hard drive ribbon cable as a very close second. Removing the battery and placing the new battery was quite easy, and routing the cable so it would pop back together was easy enough. After replacing the battery, I was able to breathe new life into an otherwise fancy paperweight.
Mein Rat
be very careful popping apart the case, because the lock switch assembly and headphone jack can be ripped from the internal logic board and wreak havoc to that board. bottom first, then work around to the top. CAREFULLY.
iPod 3G Battery Bild
iPod 3G Battery
$13.99
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 181
