Zum Hauptinhalt wechseln
« Zurück zu allen Geschichten
Replaced iPad Air Front Panel
maliawaddell -
iPad Air Wi-Fi
Bild zur Geschichte
  • Bild #1
  • Bild #2
  • Bild #3
iPad Air Wi-Fi Front Panel Assembly Replacement
2 Stunden
Difficult
Mein Problem
My iPad had the ghost touching problem, where it just started freaking out and opening apps without being touched. My research pointed to a digitizer problem. I also had a small cracked screen area.
Meine Reparatur
I had mixed results. Eventually I fixed it. Getting the original screen off with all that adhesive was no joke. I also cracked my replacement screen trying to install the home button and had to order another. The home button still doesn't respond as well as the original. But I have a functioning iPad again! So I'll consider it a win.
Mein Rat
Definitely order the replacement assy that has the adhesive and home button pre-installed. A razor blade and a blow dryer were my main tools used to remove the screen.
iPad Air Screen Digitizer Bild
$29.99
1 Kommentar
Sounds tricky, but glad you worked it out!
Cynthia Replogle - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 166
