Zum Hauptinhalt wechseln
« Zurück zu allen Geschichten
2011 iPhone 4s First-Time Battery Replacement
Leandro de la Rosa -
iPhone 4S
Bild zur Geschichte
iPhone 4S Battery Replacement
3 Stunden
Moderate
Mein Problem
The battery's lifespan has severely degraded after 7 years. The indicator gets stuck on 1% for a long time.
Meine Reparatur
It went well with the exception of the removal of the 1.7 mm Phillips screw by the battery connector. The reason it took my battery replacement process 3 hours is that I stripped the aforementioned screw. The included iFixit screwdriver's Phillips screw attachment for reason didn't go well with the 1.7 mm screw. After I miraculously removed the stripped screw, everything else went without a hitch.
Mein Rat
Don't strip any screws. If you think you are careful during the unscrewing process, you should probably be a little bit more careful.
iPhone 4S Battery Bild
iPhone 4S Battery
$18.99
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 238
