Zum Hauptinhalt wechseln
« Zurück zu allen Geschichten
iPhone 4 5-Point Pentalobe Screwdriver modification needed
dbuckel -
iPhone 4 Verizon
Bild zur Geschichte
iPhone 4 Verizon Rear Panel Replacement
5 Minuten
Easy
Mein Problem
Purchased the screwdriver to repair a broken back cover on an iPhone 4.
Meine Reparatur
Fixing the iPhone was very easy and quick. Unfortunately, the screwdriver had to be modified prior to use. The tip of the screwdriver was too long and came to too fine of a point to grip the screw.
Mein Rat
Very, and I mean VERY, gently grind or file off a small amount of the excess tip. I'd suggest grinding a little and testing the fit and then grinding some more if needed. Be sure to keep the tip square to the grinder.
P2 Pentalobe Screwdriver iPhone Bild
$5.99
iPhone 4 (CDMA/Verizon) Blank Rear Glass Panel Bild
$9.99
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 8
Insgesamt: 204
