Einleitung
Since the dawn of the iPad, Apple has remained resolute that the iPad is meant to be enjoyed sans-stylus. So when the iPad Pro debuted with a $99 must-have accessory in the form of a stylus, we were obviously intrigued. What makes the Apple Pencil so special? From what we've heard, it's got some nifty features, but we're more interested in what's going on inside that shiny white cylinder. Join us as we find out!
Looking for more gadget teardowns? Follow us on Facebook, Instagram, or Twitter to get the latest teardown news first!
Was du brauchst
Einführungsvideo
Apple's been tight-lipped on this pointer's finer points, but here's what we know for sure:
Bluetooth 4.1
Scans at twice the rate of finger inputs
Up to 12 hours of battery life
175 mm (L) x 8.9 mm (D)
Lightning connector for charging
There's been a lot of talk about Pencil. Let's sketch out a couple quick comparisons to some other styling styluses.
First: the Microsoft Surface Pen (from a Surface Pro 4).
Second: The original "iPad Pencil" by 53. It works specifically with their Paper app, and has a lot of the same features as the new Apple Pencil.
Apple was nice enough to include a spare tip, as well as a Lightning-to-Lightning adapter (a last minute addition) to save users from having to precariously charge their Pencils directly from their iPads.
The Lightning Connector cap snaps into place with magnets, but we're expecting most of these will be lost by next month.
Popping the cap off reveals a brand new, never-before-seen model number: A1603. Welcome to the world, Pencil!
Taking a nosedive into the Pencil, we start at the nib, which comes off quietly with a few quick twists.
A peek inside reveals a tiny metal bit sunk deeply into the tip, presumably to get as close to the screen as possible.
The digitizer on an iPad Pro should be able to determine the distance from each emitter to the screen—and from that calculate the angle of the Pencil relative to the iPad.
We're eager to get a closer look at the
eraserLightning Connector, so we turn up the heat with our trusty iOpener. -
Even after a warm conversation with our iOpener, the Lightning Connector assembly still doesn't want to come completely out of its shell, but a quick tug frees it from the Pencil.
But at what cost... We definitely tore a flex cable...
Having thoroughly dissected the top and bottom portions and finding no obvious point of entry, we throw caution to the wind and break out the big guns.
Cutting through the
BicApple Pencil's plastic casing revealsan ink cartridgea metal casing.
Whew—that was some work! Wiping up the plastic dust and pausing for a quick burrito break, we take a moment to appreciate the fruit of our efforts: Pencil sans case.
A quick glance along the inner metal cylinder reveals a tiny tri-point screw à la Apple Watch.
Below the tiny fastener, we spy some tiny contacts, which we assume are for Apple's internal testing.
After some more cutting and prying—and a brief conversation about laser cutters—we bust through a second (this time metal) layer.
We're rewarded with the antenna and battery assembly. No graphite at the core of this Pencil.
This tiny 3.82 V, 0.329 Wh lithium-ion battery holds just 5% of the charge of an iPhone 6s battery.
With the metal casing off, we pop off the antenna, decked in the familiar Apple black and gold.
We also get a better look at that ribbon cable we sheared earlier... It runs between the Lightning connector and battery, with some battery charging ICs along the way (we assume).
We've caught sight of more chips at the other end, so we ditch the battery and move to the fun stuff—like the teeeny logic board!
What is this—a logic board for ants? Not quite, but weighing in at a whopping 1.0 gram it's definitely the smallest we've ever seen. With the hard work out of the way, we pause to see what makes the Pencil so smart:
STMicroelectronics STML151UCY6 Ultra-low-power 32-bit RISC ARM-based Cortex-M3 MCU
STMicroelectronics STMLS05 5-channel PMOS load switches
STMicroelectronics STM32L052T8 32-Bit ARM Cortex-M0+ Microcontroller w/ 64 Kb flash
Maxim Integrated MAX11290 24-bit delta-sigma A/D converter (likely)
Cambridge Silicon Radio (Qualcomm) CSR1012A05 Bluetooth smart IC
Bosch Sensortec BMA282 accelerometer
Maxim Integrated MAX44284 high precision current-sense amplifier
We turn back to the metal casing to extract the pen nib and look for its sensor magic.
Peeling up one of the tiniest boards we've ever seen we find a set of three matching ticks. Three on the end of the pen assembly, and three on the tiny board.
If we had to hazard a guess, we'd say these helped sense pressure by measuring movement between these two parts.
Chances are this chip could tell us more about how this works...
It reads 8529043 343S00008-A1—likely a custom STMicroelectronics controller for the nib.
Further teardown of the tip seems impractical, but that's okay: we have eyes everywhere, thanks to some slick X-ray imaging from our pals at Creative Electron.
Get a load of that tiny spring-loaded tip, and the two emitters buried within the shaft.
Just for kicks, we also imaged the itty bitty folded logic board, and the Lightning Connector and cap.
Apple Pencil Repairability 1 out of 10 (10 is easiest to repair):
The pen nib and cap can be replaced if worn out (or lost).
The pencil is clearly not meant to be opened or repaired; you can't get inside without destroying the device.
The layers of plastic and metal holding interior components are impossible to remove without shredding.
The battery, enough for a 12 hour run, is impossible to replace, giving the device a limited lifespan.
49 Kommentare
I actually used our economy suction vise, it's pretty hefty and very stable :)
Could we get a tear down of a Surface Pen? #3 maybe #4?
