Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Speziell für diesen Teardown benötigte Werkzeuge
Dieser Teardown ist keine Reparaturanleitung. Um dein Buffalo Wireless Router zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Remove four rubber grommets, They are glued well, so it requires some force. The screw head is non-standard (Torx T9 or T10) with a "security pin". If you lack the Torx bit, you can use a thin flathead screwdriver (appx. 1.5mm) to jam into the slot. :)
    • Remove four rubber grommets, They are glued well, so it requires some force.
    • The screw head is non-standard (Torx T9 or T10) with a "security pin".
    • If you lack the Torx bit, you can use a thin flathead screwdriver (appx. 1.5mm) to jam into the slot. :)
    • On my router, I could easily snap off that screw head pin, allowing me to use standard bits.
  2. No need to pry, just pull them apart. No need to pry, just pull them apart.
    • No need to pry, just pull them apart.
  3. There are two fastened antennas There are two fastened antennas
    • There are two fastened antennas
  4. Serial interface (4 "pins") are unsoldered, and can be found in the top-right corner of the board (if the Ethernet ports were facing you). A close-up image crop shows the 4 serial through-hole "pins". Pinout: pin1 : VCC +3.3V
    • Serial interface (4 "pins") are unsoldered, and can be found in the top-right corner of the board (if the Ethernet ports were facing you).
    • A close-up image crop shows the 4 serial through-hole "pins". Pinout:
    • pin1 : VCC +3.3V
    • pin2 : GND
    • pin3 : TX
    • pin4 : RX
    • If you wish to connect using a USB TTL adapter, I suggest soldering female "jumper" wires and routing those outside the case. DO NOT CONNECT TO VCC (do not apply external power!)
    • The serial port is enabled by default, and you can watch Linux boot. If you Google around, you can find how to login to the console (this varies by OS installed on the router).
  5. Insert wisdom here. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  6. Insert wisdom here. Insert wisdom here. Insert wisdom here.
  7. Insert wisdom here. Insert wisdom here. Insert wisdom here.
  8. Insert wisdom here. Insert wisdom here. Insert wisdom here.
  9. Insert wisdom here. Insert wisdom here. Insert wisdom here.
Alexander Williams
169 Reputation
1 Anleitung geschrieben
Hey man, jst wanna ask can you replace those antennas with hing gin onces?
Tony Gqezengele - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 9
Insgesamt: 1,089
