Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
Device Won't Turn On
Pressing the power button gets no reaction.
Faulty Battery
Charge the battery by plugging in the charger. Let it sit a minute then press the power button. If the device still fails to start, there may be an issue with the battery not being able to keep a charge. If that is the case, replace the battery using this guide.
Broken Charger Cable
First, make sure that your charger port is intact. Check to make sure that you are plugged into a working electrical outlet by plugging something else into it. Check if your charger cable is broken by testing it on another laptop or testing another charger cable on your laptop.
Screen Not Working/Won't Light Up
The computer's power management system automatically goes black over time in order to save power. Press any key to turn the display back on.
Sleep Mode is Active
If the power LED is flashing the computer is probably in sleep mode. Press and release the power button to fix this.
May Be Set To an External Monitor
Press Fn and F5 to toggle the display back to the computer.
Restart Laptop
Press the power button in order to turn off the laptop. Once completely off, wait 30 seconds before turning back on.
Brightness Is Too Low
The backlight brightness can be adjusted from the keyboard. If you press and hold the Function button (fn) you can adjust the brightness with the arrow keys. If the Function button does not work, go to settings or control panel. Then find the “Hardware and Sound” section. After this proceed to “Power Options” and then click on “Change plan settings”. From there scroll down to “Display” and switch off enable adaptive brightness in all sections.
Screen Is Frozen
If the laptop is overheating, the screen will freeze. Laptops will overheat if the fan needs cleaning or is broken or if there are too many applications or windows open at once. If the fan is broken, follow this guide.
Screen Has Cracks
Follow our screen replacement guide.
Blue Screen Appears Frequently
If the system crashes and a blue screen (commonly called the Blue Screen of Death, or BSoD) appears frequently, there could be a software or processing error.
Recently Updated Software
Sometimes a recently updated bit of software can cause your computer to frequently crash, leading to frequent blue screens. Start by restarting your computer to see if that solves the problem. Completely shut down your computer and unplug all cords. Wait a minute before plugging everything back in and turning on.
Device overheating
If the laptop is overheating, the device may give a blue screen. Laptops will overheat if the fan needs cleaning or is broken, or if there are too many applications or windows open at once. Follow our fan replacement guide if the fan needs cleaning or replacement.
Broken motherboard
Keep in mind that the motherboard may be broken. If this is the case follow our motherboard replacement guide.
Keyboard/Keys Unresponsive
Your keyboard can become unresponsive if the signals between your keyboard and motherboard are having problems.
Signals not being sent/received or interpreted
Sometimes your keyboard can stop responding due to a problem in the reception of signals between the keyboard and the motherboard. The easiest fix would be to restart the laptop. Press the power button in order to turn off the laptop. Once completely off, wait 30 seconds before turning back on.
Keys Are Stuck In Place
Individual keys can get stuck in place if there is something stuck underneath the key. Turn your laptop off and remove the power cord and battery, then carefully remove the stuck key and clean the space below it.
Web pages and applications load slowly/Processing speed is slow
A Virus or Malware
A virus or malware can cause your RAM to be taken up doing things you don't want in the background. Run a security check for viruses and malware, and delete any contaminated data.
Not enough storage
Delete unneeded applications and/or saved files from the device hard drive.
Long loading times
A problem with the RAM card could cause long loading times and slow processing speeds. Replace it with this guide.
Camera application is not working
If your camera application specifically isn't working there could be a problem with your webcam. It could be damaged or its connecting wire could have come loose. Replace it with this guide.
0 Kommentare
