Nicht freigegebene Übersetzung
100%
Kohlmeier hans-joachim hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
100%
Hier starten ›
Letzte 24 Stunden: 7
Letzte 7 Tage: 34
Letzte 30 Tage: 195
Insgesamt: 13,797
11 Kommentare
How do you know when the device is broken and needs to be replaced? I have a Eufy 11S Max, purchased on Amazon in 2020.
I replaced the battery with an official Eufy battery. I performed the reset steps with a Eufy Customer Service representative. It still shows the orange (or red) light of death. The CS representative informed me that I needed to purchase a new one.
Joshua Brooks - Antwort Teilen
O k I have a robot vacuum 11s I've had it in storage quite a while. I pulled it out of storage replaced all the normal parts. Put it on the charger. Had to buy a new remote. And still I can't get it to work. I don't know what i'm doing wrong there's somebody have any information to help me
Mark L Denzer - Antwort Teilen
I had an 11S reporting dirty edge sensors (red light, 3 beeps). All three sensors simply slide out and unplug from the main board.
Using a spudger it is easy to pop them open (remove lens, then split the body) as they are only clipped together.
Water had caused corrosion on one of the phototransistor leads causing it to become detached. The sensor boards consist of just a 3mm phototransistor and a 3mm IR led (hence the 4 pins).
Replacing the damaged phototransistor fixed it. It was the front sensor, fwiw.
Repair Cafe George - Antwort Teilen
My eufy is showing red light and not charging .Pl give solution
M C Pandey - Antwort Teilen
My eufyvac11S is showing red light and also making beep sound three times.pl give me solution
ria james - Antwort Teilen
