Schritt 31 übersetzen
Schritt 31
A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part.
The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
Important: During installation, correctly position your new Lightning connector assembly so that the cutouts in the cable are exactly centered around the four screw bosses in the rear case. Otherwise, the flex cable will be misaligned and you won't be able to reconnect it to its socket on the logic board.
Nächste Zeile
Vorherige Zeile
Eine neue Zeile unterhalb einfügen
Eine neue Zeile oberhalb einfügen
Aktuelle Zeile einrücken
Aktuelle Zeile ausrücken
Aktuelle Zeile löschen
Zum nächsten Schritt springen.
Zum vorherigen Schritt springen.
Hilfe öffnen
