Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diese grundständige Anleitung beinhalten.
Schritt 5 übersetzen
Schritt 5
Rotate the display cable bracket
Use a pair of tweezers to pull the display cable bracket's clip out from under the frame's edge.
Rotate the display cable bracket toward the battery.
[title] Rotate the display cable bracket | |
[* icon_note] The display cable bracket is secured by a clip under the edge of the frame. | |
- | [* black] Use a pair of tweezers to pull the display cable bracket's clip out from under the frame's edge. |
+ | [* black] Use a pair of [product|IF145-020|tweezers] to pull the display cable bracket's clip out from under the frame's edge. |
[* black] Rotate the display cable bracket toward the battery. | |
[* icon_caution] Don't bend the battery cable too much past vertical to avoid damaging it. You only need enough space to disconnect the display press connectors and prevent the battery connector from making contact with its socket during the repair. |
