Zum Hauptinhalt wechseln
Front Panel-Baugruppe entfernen
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 7 übersetzen
Schritt 7
Front Panel Assembly Removal, Remove the front panel assembly: Schritt 0, Bild 1 von 3 Front Panel Assembly Removal, Remove the front panel assembly: Schritt 0, Bild 2 von 3 Front Panel Assembly Removal, Remove the front panel assembly: Schritt 0, Bild 3 von 3
  • Remove the front panel assembly.
  • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
  • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
  • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
  • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
  • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
Entferne die Frontpanel-Baugruppe.
Es kann sein, dass die Frontpanel-Baugruppe noch an manchen Stellen am Rahmen festklebt. Schneide dort den Kleber mit einem Plektrum auf.
Wenn an deinem neuen Display Probleme mit Phantomeingaben auftreten, kann dies gelöst werden: klebe eine Schicht von sehr dünnem Isolierband, z.B. Kapton-(Polyimide-)band auf die markierten Stellen auf der Rückseite. Touchscreens von iFixit sind bereits damit ausgestattet und benötigen keine weitere Behandlung.
Ohne diese Isolierung können diese Bereiche des Touchscreens Kontakt mit anderen Bauteilen erhalten, so dass diese Fehlfunktion entsteht.
Die Isolierung ist nicht zu erkennen und unterscheidet sich von den Schaumstoff-Schutzstreifen, die an vielen iPads eingebaut sind.
Bevor du beim Zusammenbau das neue Display einbaust, musst du alle Kleberreste vom iPad entfernen und die Klebestellen mit hochkonzentriertem (mindestens 90%igem) Isopropylalkohol und einem fusselfreien Tuch reinigen. Dadurch wird das iPad für den neuen Kleber vorbereitet; er kann dann besser haften.
Teste alle Funktionen des iPads und befestige vorgestanzte Klebestreifen auf der Rückseite des Displays. Unsere Anleitung für Displayklebestreifen hilft dir dabei, bevor du das Display endgültig festklebst.
