Zum Hauptinhalt wechseln
Samsung Galaxy S23 Ultra Back Cover Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 16 übersetzen
Schritt 16
Samsung Galaxy S23 Ultra Back Cover Replacement, Remove the back cover: Schritt 0, Bild 1 von 3 Samsung Galaxy S23 Ultra Back Cover Replacement, Remove the back cover: Schritt 0, Bild 2 von 3 Samsung Galaxy S23 Ultra Back Cover Replacement, Remove the back cover: Schritt 0, Bild 3 von 3
  • Grab and remove the back cover.
  • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
  • During reassembly:
  • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
  • If you're using custom-cut adhesives, follow this guide.
  • If you're using double-sided tape, follow this guide.
Hier Übersetzung einfügen
