Zum Hauptinhalt wechseln
케이블 커넥터 인식 및 연결 해제
Englisch
Koreanisch
Schritt 13
Recognizing & Disconnecting Cable Connectors, Bundled Cable Connectors: Schritt 0, Bild 1 von 2 Recognizing & Disconnecting Cable Connectors, Bundled Cable Connectors: Schritt 0, Bild 2 von 2
  • Bundled cable connectors have many small wires leading into them, often wrapped in a sleeve. They may not have anywhere to push with a spudger or a spot to grip with tweezers. Pulling on the cables themselves might be the only option.
  • This should be a last resort if the sliding connector and JST connector disconnection methods didn't work.
  • Grip all the cables at once as close to the connector as possible and pull the connector slowly and steadily out of its socket.
  • Pull evenly on the full width of the cables so no individual wires are strained.
  • To reconnect, align the connector and use a spudger or clean fingernail to push the connector head fully into the socket.
하나의 커넥터에 개별로 싸인 많은 전선이 연결되어 있으면 케이블 자체를 당기는 것이 가장 좋은 방법입니다.
개별 전선이 연결된 동일한 방향으로 커넥터에서 케이블을 당겨 빼세요.
개별 전선에 무리가 가지 않도록 케이블 전체 너비에 힘을 고르게 가하여 잡아 당기세요.
[title] Bundled Cable Connectors
-[* black] If you see a cable made up of lots of individually wrapped wires leading into a single connector, pulling on the cable itself may be the best method.
-[* black] Pull the cable away from the connector in the same direction as the individual wires are running.
-[* icon_caution] Pull evenly on the full width of the cable so that no individual wires are overly strained.
+[* icon_note] Bundled cable connectors have many small wires leading into them, often wrapped in a sleeve. They may not have anywhere to push with a spudger or a spot to grip with tweezers. Pulling on the cables themselves might be the only option.
+ [* icon_caution] This should be a last resort if the [guide|25629|sliding connector|stepid=64975|new_window=true] and [guide|25629|JST connector|stepid=370865|new_window=true] disconnection methods didn't work.
+[* black] Grip all the cables at once ''as close to the connector as possible'' and pull the connector slowly and steadily out of its socket.
+ [* icon_note] Pull evenly on the full width of the cables so no individual wires are strained.
+[* icon_reminder] To reconnect, align the connector and use a spudger or clean fingernail to push the connector head fully into the socket.
