Zum Hauptinhalt wechseln
케이블 커넥터 인식 및 연결 해제
Englisch
Koreanisch
Schritt 14
Recognizing & Disconnecting Cable Connectors, Glued-Down Cables: Schritt 0, Bild 1 von 2 Recognizing & Disconnecting Cable Connectors, Glued-Down Cables: Schritt 0, Bild 2 von 2
Glued-Down Cables
  • Sometimes removing the connector from its socket isn’t enough—an additional step or two is required to free up the cable. Here we have a ribbon cable that is lightly glued into place.
  • To remove it, carefully slide a spudger or opening pick under the cable to separate its adhesive.
  • For particularly delicate or stubborn cables, a little heat from a hair dryer, heat gun, or our handy iOpener will help soften the adhesive.
때로는 소켓에서 커넥터를 분리하는 것만으로는 충분하지 않을 때가 있습니다; 케이블을 빼기 위해 한 두 가지 추가 단계가 필요합니다. 여기 Lightning/라이트닝 포트 리본 케이블이 살짝 접착되어 있습니다.
분리하려면 spudger/스퍼저나 기타 픽을 케이블 아래로 조심히 밀어 케이블을 접착제로 부터 분리하세요.
특별히 부서지기 쉽거나 분리하기 어려운 케이블은 열선총, 헤어 드라이어, 또는 자사의 유용한 iOpener에서 나오는 약간의 열로 접착제를 부드럽게 하세요.
[title] Glued-Down Cables
-[* black] Sometimes removing the connector from its socket isn’t enough; an additional step or two is required to free up the cable. Here we have a Lightning port ribbon cable that is lightly glued into place.
-[* black] To remove it, carefully slide a spudger or guitar pick underneath the cable, freeing it from the adhesive.
-[* icon_note] For particularly delicate or stubborn cables, a little heat from a heat gun, hair dryer, or our handy [product|IF145-198-2|iOpener] will help soften the adhesive.
+[* icon_note] Sometimes removing the connector from its socket isn’t enoughan additional step or two is required to free up the cable. Here we have a ribbon cable that is lightly glued into place.
+[* black] To remove it, carefully slide a spudger or opening pick under the cable to separate its adhesive.
+ [* icon_note] For particularly delicate or stubborn cables, a little heat from a [guide|157348|hair dryer|new_window=true], [guide|151116|heat gun|new_window=true], or our handy [guide|25705|iOpener|new_window=true] will help soften the adhesive.
