Zum Hauptinhalt wechseln
케이블 커넥터 인식 및 연결 해제
Englisch
Koreanisch
Schritt 15
Recognizing & Disconnecting Cable Connectors, SATA Cables: Schritt 0, Bild 1 von 2 Recognizing & Disconnecting Cable Connectors, SATA Cables: Schritt 0, Bild 2 von 2
SATA Cables
  • Some common internal power and data cables, like these SATA cables, work much like the regular audio/video cables you already have around the house.
  • To remove them, pull in the direction of the cable.
  • Some variants of the SATA cable have a small metal release tab on the side that you may need to press before pulling.
이 SATA 케이블 같이, 어떤 흔한 내부 전원 및 데이터 케이블은 이미 집안에서 사용하는 일반 오디오/비디오 케이블과 매우 비슷합니다.
케이블을 분리하려면, 그냥 케이블 방향으로 당기세요.
SATA 케이블의 사소한 차이로는 측면의 작은 릴리스 탭 또는 버튼입니다.
손가락으로 탭을 누른 상태에서 케이블을 당겨 뺍니다.
[title] SATA Cables
-[* black] Some common internal power and data cables, like these SATA cables, work much like the regular audio/video cables you already have around the house.
-[* black] To remove them, just pull in the direction of the cable.
- [* icon_note] Some variants of the SATA cable have a small release tab or button on the side.
- [* black] Hold the tab down with your finger, and then pull to remove the cable.
+[* icon_note] Some common internal power and data cables, like these SATA cables, work much like the regular audio/video cables you already have around the house.
+[* black] To remove them, pull in the direction of the cable.
+ [* icon_note] Some variants of the SATA cable have a small metal release tab on the side that you may need to press before pulling.
